You are here: PSPad forum > English discussion forum > A few minor problems
Posted by: idefix2 | Date: 2021-03-26 03:26 | IP: IP Logged
Again with autoreplace
1. This is a screenshot after I have added the semicolumn in line 688:
[link]https://mega.nz/file/yk4EwDqL#kCgahepWqqVKcPF4X4RPOdQG3TDT6GyGrtn43YW08Dk[/link]
This only happens when I insert add a semicolumn at the beginning of a word. A semicolumn alone does not open the autocomplete window.
2. Normally, I work with PsPad on my primary screen. There, everything is fine. But if I have Pspad open on my secondary screen, the autocomplete window appears at the right edge of the screen instead of near the cursor.
Edited 1 time(s). Last edit at 2021-03-26 03:26 by idefix2.
Posted by: pspad | Date: 2021-03-27 11:24 | IP: IP Logged
1. I found problem in Autocomplete, it will be fixed this weekend build.
2. I need info about your monitors. One next to other or bellow the other? Both has same resolution?
Posted by: idefix2 | Date: 2021-03-29 09:00 | IP: IP Logged
The main monitor is the left one, the second is to the right. Both have a resolution of 1920*1280.
The address range of both screens together is 3840*1280.
Posted by: pspad | Date: 2021-03-29 09:35 | IP: IP Logged
I hope I found and fixed problem, thanks.
Can you test the current 5.0.6 build?
Edited 1 time(s). Last edit at 2021-03-29 09:36 by pspad.
Posted by: idefix2 | Date: 2021-04-01 21:48 | IP: IP Logged
Yes I can confirm that this issue is solved.
Alas no parentheses in autoreplace, so I had to go back to the previous version.
Posted by: pspad | Date: 2021-04-02 03:13 | IP: IP Logged
There is an option for brackets in autocomplete. Deactivated as default. You need to enable it
Program settings / Editor 2 - Autocomplete includes first bracket
Edited 1 time(s). Last edit at 2021-04-02 04:58 by pspad.
Posted by: idefix2 | Date: 2021-04-06 02:01 | IP: IP Logged
Ah, thank you! I had looked for that option, but still have overseen it.
