You are here: PSPad forum > English discussion forum > Text Diff function is broken in x64 version 5.0.4 (395)
#1 Text Diff function is broken in x64 version 5.0.4 (395)
Posted by: @msterdam | Date: 2020-05-12 12:08 | IP: IP Logged
I just upgraded to the newest beta version 5.0.4 (395) x64, and it appears that the Text Diff function is broken.
When reverting back to the x32 version it is fine again.
Reading through the forum I found out that this x64 problem was reported before, but apparently has not been fixed yet.
Since this Text Diff function is a very useful feature for me, and I sometimes work with very large files, I would love to have this in the x64 version as well.
So is there any change that this will be fixed in the future?
Thanks.
#2 Re: Text Diff function is broken in x64 version 5.0.4 (395)
Posted by: pspad | Date: 2020-05-12 12:36 | IP: IP Logged
Yes, in 64b version are still some problems. On the other side, there is no reason why to use 64b version, if you don't need to work with huge files.
#3 Re: Text Diff function is broken in x64 version 5.0.4 (395)
Posted by: @msterdam | Date: 2020-05-12 17:42 | IP: IP Logged
OK, thanks Jan, I will keep an eye on it.
Thanks again for your great software.
Cheers.
#4 Re: Text Diff function is broken in x64 version 5.0.4 (395)
Posted by: tmpad | Date: 2020-05-13 20:23 | IP: IP Logged
I also suffer from the text diff issue in the 64bit version.
Microsoft stopped shipping Windows 10 32bit to OEMs.
64bit versions of Windows have a (Windows) market share of appx. 97%
Perhaps it's time to drop the 32bit version and focus on the 64bit version of PSPad.
#5 Re: Text Diff function is broken in x64 version 5.0.4 (395)
Posted by: pspad | Date: 2020-05-13 20:43 | IP: IP Logged
Do you want to use 64b application only from reason you have 64b system?
#6 Re: Text Diff function is broken in x64 version 5.0.4 (395)
Posted by: hansi77 | Date: 2021-03-04 07:01 | IP: IP Logged
Hi Jan,
I like PSPad, really good work smiling smiley
I use PSPad in the 64bit version for some time now to be able to work huge files.
Unfortunately, the Text Diff doesn't work in version 5.0.5 (567) neither.
I would like to gently encourage you to have a look at this feature smiling smiley
It is really helpful.
Regards
Hansi
#7 Re: Text Diff function is broken in x64 version 5.0.4 (395)
Posted by: pspad | Date: 2021-03-04 12:05 | IP: IP Logged
hansi77:
Can you send me some example?
#8 Re: Text Diff function is broken in x64 version 5.0.4 (395)
Posted by: hansi77 | Date: 2021-03-05 07:14 | IP: IP Logged
yes,
just open two files with slightly different content:
line1=1
line2=2
line3=3
second file:
line1=1
line2=2.2
line3=3
and compare them (using the context menue at the tab)
hth
Hansi
#9 Re: Text Diff function is broken in x64 version 5.0.4 (395)
Posted by: pspad | Date: 2021-03-09 07:49 | IP: IP Logged
64b version was fixed in 5.0.6 - available in the PSPad developer forum.
Same as HEX editor fix in 64b version
#10 Re: Text Diff function is broken in x64 version 5.0.4 (395)
Posted by: hansi77 | Date: 2021-03-10 06:42 | IP: IP Logged
Hi Jan,
I can confirm that the text diff is working now smiling smiley
Thank you very much!
Best Regards
Hansi
