You are here: PSPad forum > English discussion forum > About default pattern of filename at File-Open
#1 About default pattern of filename at File-Open
Posted by: compos | Date: 2020-10-21 06:21 | IP: IP Logged
When I call "File-Open" then in some cases the pattern of filename is
"Text (*.txt, *.nfo, ...)"
I switch to pattern
but this settings does not saved for next using "File-Open".
Is any approach to save my preferred pattern?
Best regards,
Alex
#2 Re: About default pattern of filename at File-Open
Posted by: pspad | Date: 2020-10-21 06:30 | IP: IP Logged
Oúpen dialog and New file is driven by program settings / File and dirs
If you want to remember your filter, check option [x]Remember last filter
You can set file type for new file there e.t.c.
