You are here: PSPad forum > English discussion forum > Javascript no support syntax highlighting for template literals
Posted by: RANZI | Date: 2020-07-29 14:28 | IP: IP Logged
Since Emacs2015, a new syntax appears for string syntax called "templace literals", cf. developer.mozilla.org
Can you support this to a future version of PSPad ?
Thank you
Posted by: pspad | Date: 2020-07-29 15:58 | IP: IP Logged
Yes, I can add support for it
Posted by: RANZI | Date: 2020-07-30 08:46 | IP: IP Logged
Excellent
Thank's
Posted by: pspad | Date: 2020-08-04 20:07 | IP: IP Logged
Literals including template support are ready. The only thing I am not able to do is nested literals in templates, something like:
const classes = `header ${ isLargeScreen() ? '' :
`icon-${item.isCollapsed ? 'expander' : 'collapser'}` }`;
Suport for literals will be available in the next build
Posted by: RANZI | Date: 2020-08-12 10:29 | IP: IP Logged
I test with PSPad 5.0.4(517)
The highlighting is not good for the last example with "In ES2015 with nested template literals" defined in developer.mozilla.org
Posted by: pspad | Date: 2020-08-12 11:21 | IP: IP Logged
I wrote that nested templates are not supported yet.
I am not sure gow much nested templates will be used, cause it makes code near unreadable.
Posted by: RANZI | Date: 2020-08-12 14:19 | IP: IP Logged
pspad:I wrote that nested templates are not supported yet.
No problem, I don't plan to use it either
