You are here: PSPad forum > English discussion forum > Regular Expresion (Range + Integers only) CSV
#1 Regular Expresion (Range + Integers only) CSV
Posted by: maki | Date: 2020-04-24 15:18 | IP: IP Logged
^([1-9]|[1-7][0-9]|80)$
Find Only Integer 1-80
Input:
123,80
1245,65
12329,80.3
12330,12.43103448
12331,114
12332,17.85714286
12333,27.10344828
12334,120.4285714
12335,27.44444444
12336,17.48076923
12337,13.75409836
"," - separator CSV cell
Shouldbe Output result:
65
80
Error: any Match NOT FOUND!
Edited 3 time(s). Last edit at 2020-04-24 15:20 by maki.
#2 Re: Regular Expresion (Range + Integers only) CSV
Posted by: pspad | Date: 2020-04-24 15:28 | IP: IP Logged
Any match found is correct according to you expression.
#3 Re: Regular Expresion (Range + Integers only) CSV
Posted by: maki | Date: 2020-04-24 15:32 | IP: IP Logged
Problem with "."
Works with ","
Integers Only support only "," (CSV)
I am looking for a workaround
Edited 1 time(s). Last edit at 2020-04-24 15:33 by maki.
#4 Re: Regular Expresion (Range + Integers only) CSV
Posted by: pspad | Date: 2020-04-24 15:38 | IP: IP Logged
Problem is with ^ char in your exoression
#5 Re: Regular Expresion (Range + Integers only) CSV
Posted by: maki | Date: 2020-04-24 16:14 | IP: IP Logged
Without "^"
However, there is still a problem with Integers Only
Number 15 and 13 - correct
Other Number Wrong
Edited 3 time(s). Last edit at 2020-04-24 16:19 by maki.
