You are here: PSPad forum > English discussion forum > 5.0.3 (377) - "Trim Trailing Spaces" does not work !
Posted by: turkmenkoksal2017 | Date: 2020-03-03 14:17 | IP: IP Logged
Hello ,
Thank you for your great job.
I downloaded and installed the version 5.0.3 (377) , but the "Trim Trailing Spaces" does not work !
So , I back to use version 5.0.1 (305).
I guess this feature does not work on latest 5.0.4.
Thank you.
Turkmen
Posted by: pspad | Date: 2020-03-03 14:25 | IP: IP Logged
What does it means "doesn't work"
This function trims spaces from the end of the line during editation.
Posted by: turkmenkoksal2017 | Date: 2020-03-03 14:35 | IP: IP Logged
yes, it should be trim the spaces end of the line.
But it does not trim anymore.
Posted by: pspad | Date: 2020-03-03 14:42 | IP: IP Logged
Just tested and it works for me. When the option Trim trailing spaces (Program settings / Editor) is enabled, spaces are trimmed when you leave the line.
Posted by: turkmenkoksal2017 | Date: 2020-03-03 14:46 | IP: IP Logged
I installed the 5.0.4 - 381 NOW.
It does trim it when you edit the line !
Posted by: pspad | Date: 2020-03-03 14:52 | IP: IP Logged
I didn't make any changes between 5.0.3 and 5.0.4 with this functionality.
Posted by: turkmenkoksal2017 | Date: 2020-03-03 15:05 | IP: IP Logged
Thank you for your help.
