You are here: PSPad forum > English discussion forum > language suggestion
Posted by: Gabriel_ACE | Date: 2020-01-30 13:58 | IP: IP Logged
the .DEF files have descriptions which must be modified if you want to have everything in the same language
My suggestion is that the descriptions be saved in a secondary file and that it be activated together with the program language selection (if it exists show transaltion
else show the original)
for example
cobol.def
[S.ADD | descrip1]
ADD %Variable1% TO %resultado% END-ADD
[S.ADD2 | LALALALALALALALA]
ADD2 %Variable1% TO %resultado% END-ADD
cobol.def.spanish
descrip1= "esto es un texto"
LALALALALALALALA= "otro texto"
cobol.def.english
descrip1= "This is a Text"
LALALALALALALALA= "another text"
what do you think??
is possible?
Best Regards!!
