You are here: PSPad forum > English discussion forum > Replace with HTML tags to NORMAL character?
Goto Page: 1 2 Next
#1 Replace with HTML tags to NORMAL character?
Posted by: maki | Date: 2020-01-27 11:09 | IP: IP Logged
Replace with HTML tags to NORMAL character? How?
PSPad -> ! -> Find a TAG
The text must contain all hard spaces!
#2 Re: Replace with HTML tags to NORMAL character?
Posted by: maki | Date: 2020-01-27 11:35 | IP: IP Logged
I want fix:
#3 Re: Replace with HTML tags to NORMAL character?
Posted by: pspad | Date: 2020-01-27 12:17 | IP: IP Logged
Use user converter
#4 Re: Replace with HTML tags to NORMAL character?
Posted by: maki | Date: 2020-01-27 12:22 | IP: IP Logged
Are you kidding me? A handful of useless help.
#5 Re: Replace with HTML tags to NORMAL character?
Posted by: pspad | Date: 2020-01-27 12:24 | IP: IP Logged
maki:
In the list of user convertors (menu Tools) are ready to use convertors what convert entity to chars and chars to entity.
I guess, you are able to delete all unnecessary replacement and let there only 4 you want.
Instead of writing you should thinking, at least sometimes
Edited 1 time(s). Last edit at 2020-01-27 12:25 by pspad.
#6 Re: Replace with HTML tags to NORMAL character?
Posted by: maki | Date: 2020-01-27 12:43 | IP: IP Logged
I know, but some items are missing:
HTMLEntity1.ini
Edited 1 time(s). Last edit at 2020-01-27 12:44 by maki.
#7 Re: Replace with HTML tags to NORMAL character?
Posted by: pspad | Date: 2020-01-27 12:50 | IP: IP Logged
I though you know to write. Add 2 lines:
#8 Re: Replace with HTML tags to NORMAL character?
Posted by: pspad | Date: 2020-01-27 12:53 | IP: IP Logged
I see the forum deleted hard space.
On the first line before pipe char:
put cursor before | char for
open PSpad ASCII chart (Alt+A)
list down for char 160
dblclick on first column, where is hard space (nothing visible)
#9 Re: Replace with HTML tags to NORMAL character?
Posted by: maki | Date: 2020-01-27 13:45 | IP: IP Logged
If possible, can add a feature Converting?
HTML entity encoder/decoder
Unicode to HTML Character Entity Reference
Edited 2 time(s). Last edit at 2020-01-27 13:48 by maki.
#10 Re: Replace with HTML tags to NORMAL character?
Posted by: maki | Date: 2020-01-27 14:07 | IP: IP Logged
But rather you will not do the operation in PSPad, it uses too much memory and possible failure BSOD
0x0000003b (SYSTEM SERVICE EXCEPTION)
Goto Page: 1 2 Next
