You are here: PSPad forum > English discussion forum > How to Create List?
Posted by: maki | Date: 2019-12-26 08:32 | IP: IP Logged
How to Create List?
h..tps://www.example.com/example/example&s=0
h..tps://www.example.com/example/example&s=50
h..tps://www.example.com/example/example&s=100
h..tps://www.example.com/example/example&s=150
h..tps://www.example.com/example/example&s=2250
How to always instantly create any list according to the example pattern, and only subpage jump every 50 ?
I would ask for help.
PSPad ALT + I
Posted by: pspad | Date: 2019-12-26 10:19 | IP: IP Logged
In 2 steps using Alt+I:
1. generate list of numbers and select it
2. insert text for all lines into begin
Posted by: maki | Date: 2019-12-28 12:35 | IP: IP Logged
Test- not work!
postimg.cc
Edited 1 time(s). Last edit at 2019-12-28 12:36 by maki.
Posted by: pspad | Date: 2019-12-28 12:45 | IP: IP Logged
Your test is wrong.
I guess you did it on empty file
Make some lines, select it and test it again.
Insert test to lines work on selection. See the help for more info.
Posted by: maki | Date: 2019-12-28 14:12 | IP: IP Logged
It still doesn't work properly. My friend also said it works badly.
Wrong!!!
150www
250www
350www
Edited 2 time(s). Last edit at 2019-12-28 14:14 by maki.
Posted by: maki | Date: 2019-12-28 14:40 | IP: IP Logged
What is the regex that finds numbers 50 - 3150 /jump to 50?
I don't have time, I want to process any lists, and I have VERY LARGE of them, so how do you generate it with one click?
Edited 1 time(s). Last edit at 2019-12-28 14:42 by maki.
Posted by: pspad | Date: 2019-12-28 15:27 | IP: IP Logged
If you want it in one click, write script for it.
You are still the same. You don't have time and you demanding solution.
Hire somebody and pay to him to do your job instead of you.
Edited 1 time(s). Last edit at 2019-12-28 15:28 by pspad.
Posted by: maki | Date: 2019-12-28 15:49 | IP: IP Logged
This forum probably doesn't help the user.
You demand payment for everything.
SOLVED!!! :D
ALT+N
fIRST lINE, iNCREMENT:xxx
nUMBER OF lINES:xxx
DECIMAL:xxx
Edited 3 time(s). Last edit at 2019-12-28 15:53 by maki.
Posted by: pspad | Date: 2019-12-28 16:05 | IP: IP Logged
Please read your request and reactions.
You want solution.
You are demanding answers immediately. Just now is Saturday, it's Christmass time. And as you can see, I am trying to help you.
You are demanding solutions, cause you have no time.
And we all should have time to answer your question and request? Who requested payment for answer from you?
I recommended you, if you need solution immediately, to hire anybody, who will do your job instead of you.
Posted by: maki | Date: 2019-12-28 16:18 | IP: IP Logged
But some operations cannot be performed. Various errors appear, or do not work as expected.
I used Current version 5.0.2
