You are here: PSPad forum > English discussion forum > Some help with Clip Hotkeys?
Posted by: pincopallino | Date: 2019-12-30 09:51 | IP: IP Logged
Greetings,
I have been trying to figure out how to efficiently use the Clip Hotkeys but I am a bit stuck so I send a message in a bottle, hoping some rescue ship navigating around may give me a hand.
Among the pre-formatted Clip Hotkeys we have CTRL+B for <strong></strong>. It works quite erratically: sometimes nothing is inserted. I do not know why.
Following the same model, I have edited the HTML.def file for "emphasis". I have found
[em | emphasis]
<em>ァ|</em>
and modified it as follows
[em | emphasis]*Ctrl+E
<em>ァ|</em>
No effect, I get instead a sort of search box in the "Log" pane.
Ctrl+U results in insertion of ” whereas Shift+Ctrl+U should result in „ but actually nothing happens.
I am quite confused.
Also, I would love a shortcut for <a target="_blank" href=""></a>, which I use frequently. Is that possible?
Thank you in advance for any help you may provide.
Posted by: pspad | Date: 2019-12-30 10:13 | IP: IP Logged
You did your modification correctly, but you used Sortcut, what is already used.
If you insist on the Ctrl+E, and you don't need to use incremental search, go to program settings / KeyMap
You can "print" there all the shortcuts
You can remove Ctrl+E for incremental search:
click on the search in the left list, click on the Incremental search and delete shortcut
§ - selected text
| - cursor position after clip is inserted
Posted by: pincopallino | Date: 2019-12-31 18:40 | IP: IP Logged
Ah, that made the trick, thanks! Now that I've got a hint, I'll explore a bit more and if I'm stuck I'll ask again.
Thank you for your help!
