You are here: PSPad forum > English discussion forum > TextDiff dropbox only with Code Explorer Window
Posted by: joemarfice | Date: 2020-01-04 03:36 | IP: IP Logged
I'm not sure if this is a bug or a feature, but the handy "TextDiff" dropbox that pops up in the upper right when you drag a new file over PSPad only seems to appear if the Code Explorer Window is visible (Ctrl+Shift+E).
I can't find it documented anywhere... so maybe this question at least will provide a clue if anyone else is trying to find out where it went.
That dropbox popup is one of my favorite things about PSPad, BTW.
Posted by: pspad | Date: 2020-01-04 12:07 | IP: IP Logged
The problem is in left panel. If the left panel is visible, drop box appear. If isn't visible, there is no drop box.
It's a bug and I will fix it.
Posted by: pspad | Date: 2020-01-04 12:26 | IP: IP Logged
Fixed. Wait for the next build
