You are here: PSPad forum > English discussion forum > Win10/32 asks me EVERY SINGLE TIME if I want to allow PSPad to make changes to my PC.
Goto Page: 1 2 Next
#1 Win10/32 asks me EVERY SINGLE TIME if I want to allow PSPad to make changes to my PC.
Posted by: silverwoodchuck47@yahoo.com | Date: 2016-08-26 16:36 | IP: IP Logged
How do I fix the issue of Win10/32 asking me EVERY SINGLE TIME if I want to allow "this app" (PSPad) to make changes to my PC?
It's from a dialog box that is titled "User Account Control".
I want PSPad to start without Windows asking me stupid questions. Thanks.
#2 Re: Win10/32 asks me EVERY SINGLE TIME if I want to allow PSPad to make changes to my PC.
Posted by: pspad | Date: 2016-08-26 16:42 | IP: IP Logged
You installed PSPad as portable into Program Files or you set compatibility mode or ...
This isn't standard PSPad behavior.
Start PSPad as administrator, go to program settings / System integration and check multiuser environment.
#3 Re: Win10/32 asks me EVERY SINGLE TIME if I want to allow PSPad to make changes to my PC.
Posted by: silverwoodchuck47@yahoo.com | Date: 2016-08-26 17:02 | IP: IP Logged
I did as you instructed. I started PSPad as administrator and the Multi-user environment box is already checked.
#4 Re: Win10/32 asks me EVERY SINGLE TIME if I want to allow PSPad to make changes to my PC.
Posted by: pspad | Date: 2016-08-26 17:21 | IP: IP Logged
Check if folder where you installed PSPad isn't marked as ReadOnly.
I hope you didn't set any compatibility mode for PSPad.
#5 Re: Win10/32 asks me EVERY SINGLE TIME if I want to allow PSPad to make changes to my PC.
Posted by: silverwoodchuck47@yahoo.com | Date: 2016-08-26 17:52 | IP: IP Logged
Something is messed up. When I clear the checkbox in the Properties dialog to the PSPad folder in Program Files, something puts the checkbox back.
So this appears to be a Windows security issue, which never made sense to me. I want to use PSPad, not horse around with Windows' security settings.
#6 Re: Win10/32 asks me EVERY SINGLE TIME if I want to allow PSPad to make changes to my PC.
Posted by: pspad | Date: 2016-08-26 19:18 | IP: IP Logged
Is it really Windows dialog or dialog from any "protective" software?
Is there any other information what changes are made?
Can you provide screenshot?
You can disable PSPad scripting (Program settings / Scripting integration). Maybe any your paranoid antivirus consider using Windows Scripting Host as "dangerous".
#7 Re: Win10/32 asks me EVERY SINGLE TIME if I want to allow PSPad to make changes to my PC.
Posted by: silverwoodchuck47@yahoo.com | Date: 2016-08-26 20:14 | IP: IP Logged
It's from windows
No.
I don't see a way to attach an image. But here's the text that appears
Do you want to allow this app to make changes to your PC?
Program name: PSP editor
Verified publisher: Jan Fiala
File origin: Hard drive on this computer
Show details Yes No
Change when these notifications appear
If I click Change when these notifications appear, then the User Account Control Settings window appears.
If I click Show details, then
Program location: "C:\Program Files\PSPad editor\PSPad.exe"
appears below File origin. The dialog box doesn't tell me what exactly PSPad wants to do.
#8 Re: Win10/32 asks me EVERY SINGLE TIME if I want to allow PSPad to make changes to my PC.
Posted by: Stefan | Date: 2016-09-03 09:43 | IP: IP Logged
Chuck,
try to install PSPad outside the default ProgramFiles folders,
install e.g. to "C:\ProgramMy" or to X:\Tools" or... .
ProgramFiles folders have a special protection from Microsoft.
There are knowledges and workarounds, but just avoid "ProgramFiles".
HTH?
#9 Re: Win10/32 asks me EVERY SINGLE TIME if I want to allow PSPad to make changes to my PC.
Posted by: silverwoodchuck47@yahoo.com | Date: 2017-01-08 20:51 | IP: IP Logged
So I uninstalled PSPad and installed in my portable app folder. That fixed the problem. Lame workaround, but it works. Thanks.
#10 Re: Win10/32 asks me EVERY SINGLE TIME if I want to allow PSPad to make changes to my PC.
Posted by: pspad | Date: 2017-01-08 21:08 | IP: IP Logged
'.phorum_html_encode('silverwoodchuck47@yahoo.com').''">''.phorum_html_encode('silverwoodchuck47@yahoo.com').'':
During install process PSPad offers you standard installation or portable installation.
PSPad is portable as is from the begin. You can simple copy your PSpad folder and copy it where you need. PSPad doesn't depends of any runtime libraries or frameworks
Goto Page: 1 2 Next
