You are here: PSPad forum > English discussion forum > Print text darker
Posted by: Neil | Date: 2018-09-18 03:50 | IP: IP Logged
Hi Jan,
Is there a way to make text print darker ??
I have tried all the settings I can see, but the text still prints a lot fainter than say Notepad.
Thanks,
Neil
Posted by: pspad | Date: 2018-09-18 04:52 | IP: IP Logged
In the print preview you can switch off highlighting and in this case text will be as dark as possible
Posted by: Neil | Date: 2018-09-20 04:04 | IP: IP Logged
pspad:In the print preview you can switch off HIGHLIGHTING and in this case text will be as dark as possible
Hi Jan,
Thanks for reply.
I assume you mean switch off SYNTAX ??
Not much better I'm afraid.
Is there a way of making the text as dark as the header??
That would be good.
Thanks,
Neil
Posted by: pspad | Date: 2018-09-20 05:23 | IP: IP Logged
Hello, I meant Color print button, next to syntax button (3 vertical strips icon)
Posted by: Neil | Date: 2018-09-21 02:51 | IP: IP Logged
Hi Jan
Tried that before - no luck
Thanks
Neil
Posted by: pspad | Date: 2018-09-21 04:39 | IP: IP Logged
Can you send me some screenshot from print preview?
Posted by: Neil | Date: 2019-08-12 05:09 | IP: IP Logged
Hi Jan,
Sorry to bring this up again but is there any resolution on my problem?
Do any other users have issues with print darkness?
Thanks,
Neil
Posted by: pspad | Date: 2019-08-12 05:48 | IP: IP Logged
Call print preview dialog (Alt+P)
On the toolbar is set of options
Switch off print in colors
If it doesn't help, send me to support mail your PSPad.INI and file type you are editing. I will try to simulate and fix it.
