You are here: PSPad forum > English discussion forum > Command Window disappeared (Windows10)
Posted by: algo | Date: 2019-06-05 01:30 | IP: IP Logged
I used to run LaTeX as an external command from PSPAD.
There used to have a command window popup as I executed the compilation.
But...from some time, it disappeared.
Perhaps, I made some mistake?
PSPAD simply run it silently.
I cannot enter a command during the execution.
If the program ask to a response, it will just wait indefinitely.
Please advice me how to restore such window.
Posted by: pspad | Date: 2019-06-05 06:00 | IP: IP Logged
You run it from external command or from compiler? Compuler has more possibilities (e.g. uncheck compile on the background).
In the PSPad help is the example of batch file for Latex.
