You are here: PSPad forum > English discussion forum > How do I restore original option setting?
Posted by: algo | Date: 2019-05-26 12:48 | IP: IP Logged
Presumably I made some mistakes in the options setting.
How can I remove them ,i.e., restore the original setting?
Posted by: pspad | Date: 2019-05-26 13:19 | IP: IP Logged
All settings is in the file PSpad.ini
Close PSPad and delete this file. PSpad will create new default one.
If you installed PSPad as portable, settings is in the PSpad folder.
In case of standard installation, settings is in %appdata%\PSPpad folder
Posted by: algo | Date: 2019-05-27 01:11 | IP: IP Logged
I have deleted the old .ini file.
But it seems no use.
When I am running an external program, the MS command window do not appear.
Since I am using it to compile LaTeX file, the command window is important.
What is wrong?
Edited 1 time(s). Last edit at 2019-05-27 01:21 by algo.
Posted by: pspad | Date: 2019-05-27 03:17 | IP: IP Logged
Open PSPad help and use example for compiler.
