You are here: PSPad forum > English discussion forum > What is wrong with this error message?
#1 What is wrong with this error message?
Posted by: algo | Date: 2019-05-26 12:37 | IP: IP Logged
Exception description:
Access violation at address in module 'KERNELBASE.dll'. Write of address .
Exception address:
Stack list, generated 2019/5/26 20:33:58
(See forum.pspad.com)
INFO
- For example:
- PSPad runs for x hours.
- I had n files open.
- I had expected:
- But I got instead:
- I had verified that with:
--- older/newer builds
--- on other Computers
Thank you very much!
Program : C:\Program Files (x86)\PSPad editor\PSPad.exe 5.0.1 (312)
System : Windows 10 Home Edition x64, Version: 10.0, Build: 42EE,
Processor: Intel, Intel(R) Celeron(R) CPU N2940 @ 1.83GHz, 1833 MHz MMX
Display : 1366x768 pixels, 32 bpp PPI: 96
Active Controls Hierarchy:
TButton "bOK"
TfCMDWindow ""
Edited 3 time(s). Last edit at 2019-06-07 18:47 by Stefan.
#2 Re: What is wrong with this error message?
Posted by: pspad | Date: 2019-05-26 13:17 | IP: IP Logged
Becaouse you are not able to write any details, I am not able to tell you what is wrong.
