You are here: PSPad forum > English discussion forum > Column selection, highlighting matching text in v5
#1 Column selection, highlighting matching text in v5
Posted by: ikea7788 | Date: 2017-08-08 06:42 | IP: IP Logged
Is there any way to implement the holding of "Alt+Shift" and using the arrow keys for column selection? Such mode is present in "programmers notepad" and I find it very useful and I really miss it in PSPad.
Also the highlighting of all strings matching a selected text in the current doc. would be nice.
I haven't tried the v5 yet so sorry if those are already implemented.
#2 Re: Column selection, highlighting matching text in v5
Posted by: pspad | Date: 2017-08-08 06:50 | IP: IP Logged
How to select column block:
- Alt + mouse, if this option is enabled in program settings / Editor 1
- Select column block mode (Shift+Ctrl+C) and select block with Shift + arrows
- Select Column block mode (Shift+Ctrl+C), go to start, pres F8, move to end and press F8
#3 Re: Column selection, highlighting matching text in v5
Posted by: ikea7788 | Date: 2017-08-09 13:17 | IP: IP Logged
Yes, I am familiar with those. So none of the ones I mentioned are present. The "Select column block mode (Shift+Ctrl+C) and select block with Shift + arrows" is similar but why do we need a special mode instead of holding "Shift+Alt" down + arrows?
Edited 1 time(s). Last edit at 2017-08-09 13:19 by ikea7788.
#4 Re: Column selection, highlighting matching text in v5
Posted by: pspad | Date: 2017-08-09 13:20 | IP: IP Logged
ikea7788:
I understand, but you can simple press Ctrl+Alt+C (switch to column mode) and then select column with arrows.
#5 Re: Column selection, highlighting matching text in v5
Posted by: sadomazo | Date: 2019-05-03 20:15 | IP: IP Logged
(Ctrl + Alt + C) (switch to column mode) after switching to, with which keyboard shortcut to return to normal mode ?
Best Regards
#6 Re: Column selection, highlighting matching text in v5
Posted by: pspad | Date: 2019-05-04 04:52 | IP: IP Logged
Ctrl+Alt+N
#7 Re: Column selection, highlighting matching text in v5
Posted by: sadomazo | Date: 2019-05-04 18:43 | IP: IP Logged
I tried this combination, but it didn't work in my version (v5.0.1 (312)).
I noticed something like this (parogram settings> Key Map).
Ctrl + Shift + C = Column select
Ctrl + Shift + L = Line select
Ctrl + Shift + N = Normal select
However, because there are 2 assignments to the normal selection combination, I was opening a new tab to the press.
I erased the other assignment and it's working now.
thank you so much
best regards
#8 Re: Column selection, highlighting matching text in v5
Posted by: pspad | Date: 2019-05-05 09:08 | IP: IP Logged
In keymap / Files delete combination for new file.
