You are here: PSPad forum > English discussion forum > How to get rid of this unwanted line?
Posted by: maki | Date: 2019-03-29 13:17 | IP: IP Logged
postimg.cc
How to enable the area of the text "Wrap by Character" (max. 80 character per line)
Edited 2 time(s). Last edit at 2019-03-29 13:20 by maki.
Posted by: pspad | Date: 2019-03-29 13:24 | IP: IP Logged
Program settings / Editor 2 - set right edge to 0 or to 2000
Posted by: maki | Date: 2019-03-29 14:15 | IP: IP Logged
Again:
There are currently more than 235
Posted by: pspad | Date: 2019-03-29 14:50 | IP: IP Logged
Do you want to wrap with line or window width?
Wrap with right edge option wraps with line. This option off wraps with window width.
How to set Right edge position is in my previous answer. Anyway, everything is in the help file
Posted by: maki | Date: 2019-03-29 15:32 | IP: IP Logged
Your setting turns off the vertical line, but does not set the length of the text in the line
Where are the 4 options?
1. No Wrap
2. Wrap by Characters
3. Wrap by Window
4. Wrap by Page
Posted by: pspad | Date: 2019-03-29 16:46 | IP: IP Logged
Wrap / No Wrap - Menu View or toolbar button
Wrap with right edge / Wrap with Window witdth - se my previous answer
Wrap with char - it's something from your mind
Posted by: maki | Date: 2019-03-29 17:17 | IP: IP Logged
pspad:Wrap with char - it's something from your mind
Will you tell me how to set it Wrap by Characters!!!? What key shortcut?
[ENABLED] Word Wrap
[DISABLED] Enable Word Wrap After Marks
[ENABLED] Wrap these Characters
Not Allowed at Line Head: !?%)]},.:;
Not Allowed at Line End: ([{
Wrap by: Specified Characters
Line and Column Display as: Logical Coord. (Full-Width Char, as 2 Col.)
Normal Line Margin: 80
Quoted line Margin: 80
Quote Character: >
Edited 3 time(s). Last edit at 2019-03-29 17:24 by maki.
Posted by: pspad | Date: 2019-03-29 17:22 | IP: IP Logged
From where did you get the decription?
PSpad has no green icon. Maybe you are in the bad forum...
Posted by: maki | Date: 2019-03-29 17:27 | IP: IP Logged
He wants similar functions in PSPad
I found out, it can not be set!
So it will not show the text - as I expect.
Edited 1 time(s). Last edit at 2019-03-29 17:27 by maki.
Posted by: pspad | Date: 2019-03-29 18:15 | IP: IP Logged
Sorry, but I don't understand
