You are here: PSPad forum > English discussion forum > javascript pspad problem
Posted by: Gabriel_ACE | Date: 2019-02-11 15:30 | IP: IP Logged
hi!
I m trying to execute this sentence
var oneFile = moreFiles.item();
var n = oneFile.search(".sel");
echo(n);
but pspad don't like "search"
idem for "includes"
var n = oneFile.includes(".sel");
echo(n);
I don't understand which is the problem
Posted by: pspad | Date: 2019-02-11 15:53 | IP: IP Logged
What does mean "pspad doesn't like search"?
Posted by: vbr | Date: 2019-02-11 21:56 | IP: IP Logged
Gabriel_ACE:hi!I m trying to execute this sentence
echo(n);but pspad don't like "search"
idem for "includes"
echo(n);I don't understand which is the problem
it is difficult to find the cause of this problem without the rest of the code,
but there are some possibilities.
The type of the objects in questions is important - I believe, search is a string method and performs a regex search; it most likely is not available e.g. in an array.
incudes is an array method, but it might not be supported in all javascript engines, e.g. MS Explorer; I thing PSPad uses this browser for WSH scripting javascript, if it is present.
Could you possibly use indexOf in your code? (this seems more general and more widely available).
hth,
