You are here: PSPad forum > English discussion forum > Keyboard shortcut to switch between split windows?
#1 Keyboard shortcut to switch between split windows?
Posted by: mattpenner | Date: 2019-01-05 00:54 | IP: IP Logged
I heavily use keyboard shortcuts to switch between my open tabs. Is there a keyboard shortcut to switch between the top or bottom windows of a split document?
I know I can split a window horizontally or vertically, and I know I can create a keyboard shortcut to do that. But I'm looking for an easy way to switch between the top split window and the bottom without having to use my mouse.
I can't seem to find it anywhere in the docs nor an ability to set a keyboard shortcut to it. sad smiley
#2 Re: Keyboard shortcut to switch between split windows?
Posted by: pspad | Date: 2019-01-05 06:03 | IP: IP Logged
Yes, thete is. Use standard CTRL+Tab and Shift+Ctrl+Tab
