You are here: PSPad forum > English discussion forum > new option ???
Posted by: Gabriel_ACE | Date: 2018-12-10 14:08 | IP: IP Logged
Hi!
I usually open a file that is being updating at the same time
I need (if isn't exist) in option for set the amount of time that pspad wait until update that's open file
Posted by: pspad | Date: 2018-12-10 14:27 | IP: IP Logged
How long should be such "delay"?
Posted by: Gabriel_ACE | Date: 2018-12-11 15:33 | IP: IP Logged
seconds
thats because I work with batch process
Posted by: pspad | Date: 2018-12-11 19:20 | IP: IP Logged
If I understand, you did something in your batch and then you start PSPad with some file as parameter, right?
In this case modify your batch file to start PSPad when your file will be ready - add delay between your file generation and PSPad start
You can use command START with /wait parameter for your file creation process or add delay before PSPad start. See possibilities:
www.robvanderwoude.com
Posted by: Gabriel_ACE | Date: 2018-12-11 21:40 | IP: IP Logged
pspad:If I understand, you did something in your batch and then you start PSPad with some file as parameter, right?In this case modify your batch file to start PSPad when your file will be ready - add delay between your file generation and PSPad start
nonononononononon
I open a linux's log file from windows using pspad, thats log always is updating, but pspad dont updatethe information faster than thats prosess
Posted by: pspad | Date: 2018-12-12 05:23 | IP: IP Logged
You wrote about batch file...
OK. In the PSPad you have option for file autoupdating.
You can find it on the Window menu or the file tab context menu as "Autoupdate window"
Autoupdate interval is in the program settings / Editor 2
Ctrl+R immediately reload your file
