You are here: PSPad forum > English discussion forum > Lines are not displayed correctly after 4000 chars
Posted by: blubbb | Date: 2018-11-13 12:09 | IP: IP Logged
I'm using 5.0.1 (287).
If there is a line with more than 4000 chars, the remaining chars will be only displayed as blanks.
Posted by: pspad | Date: 2018-11-13 12:31 | IP: IP Logged
Hello.
What highlihter do you use?
Can I have any example of file? Send it to support mail please
Posted by: vbr | Date: 2018-11-13 12:40 | IP: IP Logged
I can confirm this bug, it appears even without highlighter, just in plain text mode, with basic characters (I used 0123456789 repeated more than 400 times).
with whitespase characters visible, the paragraph mark used for line ending is shown asi character 4001 and the rest of the line is invisible, however, on clicking or moving the cursor with arrow keys the expected character values are shown in the statusbar.
The wordwrapping doesn't change the behaviour here.
Pspad 5.0.1 (287) 32bit, Win 10.
Regards,
Edited 1 time(s). Last edit at 2018-11-13 12:40 by vbr.
Posted by: pspad | Date: 2018-11-13 13:45 | IP: IP Logged
OK, I will check it.
It can be join with URL highlighter, what is used (if enabled in program settings) for files without higlighter or with switched off hihglighter to make URL files active
Posted by: vbr | Date: 2018-11-13 17:14 | IP: IP Logged
pspad:OK, I will check it.
You are right, the bug appears precisely in plain txt with highlighting of URLs switched on; after switching the URL highlighting off as well as with using any other highlighter the characters after column 4000 are displayed correctly.
Posted by: pspad | Date: 2018-11-23 11:29 | IP: IP Logged
Will be fixed in the next build
