You are here: PSPad forum > English discussion forum > PSPAD5.0 popupwindow disappeared
#1 PSPAD5.0 popupwindow disappeared
Posted by: algo | Date: 2018-08-02 09:10 | IP: IP Logged
I am using Windows 10 and PSPAD 5.0 with MikTeX.
Previously when compiling MikTeX there will have a popup window displaying
the progress. However, after update to 5.0 the popup window disappeared.
The compilation is silent. How should I modify to have the popup window again?
#2 Re: PSPAD5.0 popupwindow disappeared
Posted by: pspad | Date: 2018-08-02 09:38 | IP: IP Logged
Hello check the compiler settings
[]Capture program output window (I suggest uncheck)
[]Compile on background (I suggest uncheck)
#3 Re: PSPAD5.0 popupwindow disappeared
Posted by: algo | Date: 2018-08-02 11:15 | IP: IP Logged
I did not check these two options.
It was fine for the previous version.
