You are here: PSPad forum > English discussion forum > Ctrl W wrap lines makes nothing
Posted by: giovanni | Date: 2017-12-04 10:48 | IP: IP Logged
I'm using vers. 4.6.2 and, I don't know why, the wrapping of lines text don't work anymore.
Where is the issue ?
Thanks
Giovanni
Posted by: pspad | Date: 2017-12-04 11:14 | IP: IP Logged
Are you sure Ctrl+W is assigned to Wrap lines?
When do you use menu View/Wrap line, do you see Ctrl+W shortcut? Calling WordWrap from menu doesn't work either?
Another issue - you set wordwrap with right edge (vertical line) and the line is set "somewhere", e.g. on the position 1000 or zero. Check it in the Program settings / Editor 2.
