You are here: PSPad forum > English discussion forum > Sort lines by lenght of the string
Posted by: Esgrimidor | Date: 2017-02-18 13:58 | IP: IP Logged
Each line in the txt file is a string
How to sort from the short to the longest ?
Best Regards
Nice program indeed
Posted by: pspad | Date: 2017-02-18 20:58 | IP: IP Logged
Cause it's a first time I see this request, PSPad doesn't know it.
You can add this functionality by writing own script using PSPad scripting.
It's not too hard to add it into SORT dialog as option, but I need to know rules in case 2 lines has same length. What should be expected result?
Posted by: Esgrimidor | Date: 2017-02-18 21:46 | IP: IP Logged
same length simply mantaine the initial order.
Or if you prefer in alphabetical order in the group of strings with the same length .
The important part for me is obtain grouped the strings with the same length
Best Regards
Nice program indeed
Posted by: Stefan | Date: 2017-02-20 09:14 | IP: IP Logged
pspad:You can add this functionality by writing own script using PSPad scripting.
// =========================================== Start Code
//X:\PSPad\Script\JScript\Sort.js
module_name = "StefanSort";
module_ver = "0.001a";
function Init(){
addMenuItem("Sort Random" ,"Sort", "StefanSortRandom");
addMenuItem("Sort by line length (Long to short)","Sort", "StefanSortByLineLengthDown");
addMenuItem("Sort by line length (Short to Long)","Sort", "StefanSortByLineLengthUp");
function StefanSortRandom() {
var objEditor = newEditor();
objEditor.assignActiveEditor();
objEditor.Text((objEditor.Text().split("\n")).sort(function(){return .5 - Math.random()}).join("\n").slice(0, -1));
function StefanSortByLineLengthDown() {
objEditor.Text((objEditor.Text().split("\n")).sort(function(a,b){return b.length-a.length}).join('\n').slice(0, -1));
function StefanSortByLineLengthUp() {
objEditor.Text((objEditor.Text().split("\n")).sort(function(b,a){return b.length-a.length}).join('\n').slice(0, -1));
// =========================================== End Code
slice() to remove additional added linebreak on each run.
HTH?
Edited 1 time(s). Last edit at 2017-02-20 09:15 by Stefan.
Posted by: Esgrimidor | Date: 2017-02-20 12:48 | IP: IP Logged
I will try and comment
Best Regards
Nice program indeed
Posted by: Esgrimidor | Date: 2017-02-20 13:01 | IP: IP Logged
Ejem.
I don't know how to load the script.
Can you help me ?
Best Regards
Nice program indeed
Posted by: Stefan | Date: 2017-02-20 13:39 | IP: IP Logged
Esgrimidor:I don't know how to load the script.
Can you help me ?
Yes.
Store code as "...PSPad\Script\JScript\Sort.js"
Open PSPad.
Press F1 key.
Go to "Customize PSPad" > "Script User's Guide"
(also read "Script Menu" -Topic there)
Edited 1 time(s). Last edit at 2017-02-20 13:42 by Stefan.
Posted by: pspad | Date: 2017-02-20 13:42 | IP: IP Logged
I guess the first step will be allow scripting in PSPad settings / System integration
Posted by: Stefan | Date: 2017-02-20 14:06 | IP: IP Logged
If I may,.... some additional info for to update the help:
Script User's Guide
Where are the scripts stored
Scripts are organised in subdirectories coresponding to language. The root folder for scripts comes as subfolder .\Script.
Script files are plain text files stored in that subdirectories, with an extension, corresponding to the script language used,
e.g. "vbs" for VBScript (Visual Basic Script) or "js" for JScript (MS JScript and JavaScript).
If you have found an script on the forum, save the content inside of the code block as such a file in the right folder.
Be sure "System integration > Integrated scripting support (WSH)" is enabled in PSPad.
Next find the script in the "Script Menu", the Name (caption and sub menu, if any) is taken
from the script section "addMenuItem("caption","submenu","procedure to execute")"
(See "...\PSPad\Script\readme.rtf" for more information and some example scripts)
Note that you have to execute "Script Menu > Recompile scripts" each time the script code was modified.
Just click the wanted script entry from "Script Menu" to execute that script.
Edited 2 time(s). Last edit at 2017-02-20 14:09 by Stefan.
Posted by: Esgrimidor | Date: 2017-02-21 10:06 | IP: IP Logged
What is the meaning of :
Nice program indeed
