You are here: PSPad forum > English discussion forum > Code Explorer (c/c++): Missing functions if e.g. "switch" contained.
#1 Code Explorer (c/c++): Missing functions if e.g. "switch" contained.
Posted by: FrederikS | Date: 2016-10-28 07:45 | IP: IP Logged
Hi there,
I just found that some functions are not listed in the code explorer. This includes, e.g., functions where a "keyword" like switch is included. For example:
int switch01(int& switchV){
/* Helper variable. Switches the input between 0/1
and returns the new value*/
switchV=switchV==0?1:0;
return switchV;
Is there a way to change this behaviour? Many thanks!
#2 Re: Code Explorer (c/c++): Missing functions if e.g. "switch" contained.
Posted by: pspad | Date: 2016-11-24 12:04 | IP: IP Logged
Fixed. Available in the next build
