You are here: PSPad forum > English discussion forum > aRemoveDuplicities
Posted by: Andreas.1 | Date: 2016-09-11 12:03 | IP: IP Logged
Hello. This is the best editor. I very much want to aRemoveDuplicities not case-sensitive.
Or at least, you could configure this in Settings.
Also, i very much want in the Tree Project, to tab Favorites (Links|TFLinks), the when select of link (mPSPadOpen),
and pressing the Enter, this is a link to open in PSPad.
Thank you.
Edited 3 time(s). Last edit at 2016-09-11 12:06 by Andreas.1.
Posted by: pspad | Date: 2016-09-11 13:47 | IP: IP Logged
Do you want to use RemoveDuplicities in script? If no, use Sort function, there is a possibility to do it as case sensitive. I can add action for case sensitive remove duplicities
Add enter to open file from link panel is good idea, I will do it.
Posted by: Andreas.1 | Date: 2016-09-11 14:07 | IP: IP Logged
I want to use it not only in the script, but also in hot keys.
Without sorting.
I often work with multiple lines, and often removes duplicates.
But because of the case sensitivity of the register, it is impossible to make.
Sport
sport
This duplicate will not be deleted. I need it to be removed.
Thanks
Posted by: pspad | Date: 2016-09-11 14:51 | IP: IP Logged
Done. In the next build will be new action aRemoveDuplicitiesCI (Case Insensitive)
I also added few shortcuts to Favourite panel - Enter for open, Alt+Enter for open in default application and Ctrl+Enter for edit link
