You are here: PSPad forum > English discussion forum > Notepad Link - ABB Rapid
Posted by: Nephilim | Date: 2016-07-04 13:30 | IP: IP Logged
In the PsPad folder in older installation it is inluded in the system folder C:\Program Files (x86)\PSPad editor a notepad link.
I used this link for open pspad in applications that open direct files into notepad editor.
In the last version (4.6.0) this option is not included can you please help us?
Another issue in ABB RAPID sintax. You have defined in the code explorer window Procedures (PROC) and Traps (TRAP). Can you add also Local Procedures (LOCAL PROC)? Or please explain me how to do it.
Thank you very much for the application and for the support.
Posted by: pspad | Date: 2016-07-04 13:57 | IP: IP Logged
Hello. Use notepad.exe from older pspad version.
To extend code explorer, I need some source code sample.
Posted by: Nephilim | Date: 2016-07-04 15:09 | IP: IP Logged
Hi!
I included also the Local Trap
In can include in the Procedures Tab and in the Traps tab in the code explorer that exists now with a different collor if its simple to developpe.
Thank you!
The sample code:
MODULE mMosaico12(SYSMODULE)
PROC rPaletiza_M12P1()
VAR num nTesteCamada;
MoveL Offs(pPackExtraP1{3},-150+nOffSetCal,0,((nCamACT_P1-2)*nSacoAltura)+250+nSacoAltura),vSaco,z200,tGripper\WObj:=wobjPal1;
ENDPROC
LOCAL PROC rIncrPos_P1()
nPosACT_P1:=nPosACT_P1+1;
nSacosACT_P1:=nSacosACT_P1+1;
ENDPROC
LOCAL trap tProj
!Sample Code
ENDTRAP
TRAP tProj22
!Sample code
ENDTRAP
ENDMODULE
Posted by: Nephilim | Date: 2016-07-07 15:24 | IP: IP Logged
Is the code sample enough for the upgrade?
Thank you for your help!
BR
Posted by: pspad | Date: 2016-07-08 09:08 | IP: IP Logged
Your source code is OK. I already modified code parser and it will be included in the next build in the PSPad developer forum
