You are here: PSPad forum > English discussion forum > Case sensitive autocomplete
Posted by: clanman | Date: 2013-01-30 12:10 | IP: IP Logged
Last year there was a post saying Auto complete (ctrl+j) was now case sensitive.
I have not yet been able to get this to work and still only get uppercase characters if the correct case has not been used.
I have updated my install today to build 2449 to ensure this was not the problem. See forum.pspad.com
Posted by: pspad | Date: 2013-12-05 08:18 | IP: IP Logged
Autocomplete comntent comes from 2 sources:
1. [keywords] section from the clip file definition
2. from the source you are editing.
If there is word HELLO and Hello, autocomplete will offer you both forms.
Posted by: Walf | Date: 2016-06-22 08:03 | IP: IP Logged
Case sensitive autocomplete seems to be gone (in v4.6.1 build 2716) and I haven't found any setting to re-enable it. Forcing case-insensitive snippets is exceedingly frustrating when coding in case-sensitive languages. Am I missing something?
Posted by: pspad | Date: 2016-06-22 09:07 | IP: IP Logged
I will check it.
Posted by: pspad | Date: 2016-06-23 12:44 | IP: IP Logged
In the new build case sensitive/insensitive autocompletion list will depends of highlighter settings.
Autocomplete will be case sensitive for languages set as case sensitive only.
Posted by: Walf | Date: 2016-06-27 01:04 | IP: IP Logged
That's a much better default, but I'd still rather have the choice to have case-sensitive at all times. Comments/documentation within code can still have collisions, and case-insensitive languages won't actually break if you choose the less preferable variation of,SOMEVARIABLE
andsomeVariable
Posted by: pspad | Date: 2016-06-27 04:10 | IP: IP Logged
It can be made by options.
There will be possibilities:
as default - language dependent
mode - always case insensitive
mode - always case sensitive
Edited 1 time(s). Last edit at 2016-06-27 04:46 by pspad.
Posted by: Walf | Date: 2016-07-02 06:57 | IP: IP Logged
Fantastic!
