You are here: PSPad forum > English discussion forum > get rid of xml version
Posted by: dougraider | Date: 2015-07-08 18:48 | IP: IP Logged
I've made a bad adjustment, somewhere, and now, every time I capture a file to put in pspad, it sticks this note at the top of the file and treats is like a html file.
<?xml version="1.0" encoding="windows-1250"?>
I want pspad to not insert anything and treat new files as text. Is there a setting I can change to accomplish this?
Thanks,
Doug Bell
Newbie
Posted by: vbr | Date: 2015-07-08 22:29 | IP: IP Logged
dougraider:I've made a bad adjustment, somewhere, and now, every time I capture a file to put in pspad, it sticks this note at the top of the file and treats is like a html file.<?xml version="1.0" encoding="windows-1250"?>
Thanks,
Doug Bell
Newbie
I believe, you can adjust this in
Settings: Program Settings: Files and Dirs: New default - [Text]
hth,
