You are here: PSPad forum > English discussion forum > proposal: "Ident. Bytes in UTF-8 coding" (BOM) in Format
Posted by: cyberchicken | Date: 2015-04-07 16:23 | IP: IP Logged
I think that "Ident. Bytes in UTF-8 coding" should be added to Format menu and to status bar (option should be used only for defaults, ie new files). Also add "BOM" to the label.
What do you think?
Posted by: johnbentley | Date: 2015-06-24 12:32 | IP: IP Logged
Yes, on the format menu it would be a good idea to have the following options.
"UTF-8 (with BOM)"
"UTF-8 (without BOM)"
Yes, the status bar could use the same strings.
Posted by: pspad | Date: 2015-06-24 12:43 | IP: IP Logged
I agree and it will be implemented.
Posted by: johnbentley | Date: 2015-06-26 10:22 | IP: IP Logged
Terrific, thanks Jan.
