You are here: PSPad forum > English discussion forum > How to remove that 'time tags' from file?
Posted by: patrickh111 | Date: 2014-11-17 19:15 | IP: IP Logged
Hi, i working new for several years with PSPad and never have a problem until now...
i have files were i have to delete some text, i give at once the problem here:
i´ts about a GPX file where i have to delete all the time tags
<trkpt lat="47.410760000" lon="12.714200000">
<ele>1750.000000</ele>
<time>2012-05-01T08:00:00Z</time>
</trkpt>
<trkpt lat="47.410490000" lon="12.714190000">
<ele>1752.000000</ele>
<time>2012-05-01T08:00:33Z</time>
</trkpt>
<trkpt lat="47.410330000" lon="12.714160000">
<ele>1753.000000</ele>
<time>2012-05-01T08:01:06Z</time>
</trkpt>
As you can see every tag <time>2012-05-01T08:00:00Z</time> has another code, the whole tag with the time has to be deleted.
I did try with search and replace but did not find out how to do that
please help
edit from "help needed" to "How to remove that text from file?"
Edited 2 time(s). Last edit at 2014-11-18 06:37 by Stefan.
Posted by: pspad | Date: 2014-11-17 19:34 | IP: IP Logged
1. Search / Replace dialog with regular expressions
Search: <time>.*</time>
Replace:
[x]Regular expression
After it use menu Edit / Lines manipulation / Remove blank lines
2. Find + Copy nonmatching
Replace:
[x]Copy nonmatching
press copy button and you will get your content in new editor window
Posted by: patrickh111 | Date: 2014-11-17 20:06 | IP: IP Logged
Thanks, it works, i did try <time>*</time> just a point away
