You are here: PSPad forum > English discussion forum > Suppress space in a line or group of lines
Posted by: Esgrimidor | Date: 2014-11-09 03:56 | IP: IP Logged
I would like to suppress any spaces between words (not only at the beginning of the line) of a line or line group. .
How can i do that ?
Best Regards
Nice program indeed
Posted by: pspad | Date: 2014-11-09 06:33 | IP: IP Logged
If you want to suppress all spaces, use search/replace and replace spaces with nothing.
If you want to suppress additional spaces, use function Remove redundant spaces from the menu edit / Line manipulation and check option inside text too. In case you want to use it more often, assign shortcut to this function in the program settings / Keymap.
Posted by: Esgrimidor | Date: 2014-11-09 15:46 | IP: IP Logged
Wonderful indeed. Running to try.
Best Regards
Nice program indeed
