You are here: PSPad forum > English discussion forum > Width of display window for Search & Replace in files
Posted by: Neil | Date: 2014-08-28 00:33 | IP: IP Logged
Hi Jan,
Would it be possible for you to widen the window of the Search & Replace prompt to suit the width of the line displayed.
I must have very long lines as they are always split in the display and so it is harder to determine quickly where the line is in the file.
Can I also repeat my older request that the "Replace with" toggle stays on once the user has selected it.
Thanks,
Neil
Posted by: pspad | Date: 2014-08-28 04:46 | IP: IP Logged
Did you tried the latest 4.5.8 build from the PSPad developer forum? Width of the search/replace dialog was increased
Posted by: Neil | Date: 2014-08-30 10:08 | IP: IP Logged
pspad:Did you tried the latest 4.5.8 build from the PSPad developer forum?
Hi Jan,
Yes I have got the latest version.
The number of characters displayed in the window is apporximately 60.
I realise that many users may not have longer lines, but would it be a problem if the width was increased ?
Thanks,
Neil
Posted by: pspad | Date: 2014-08-30 10:53 | IP: IP Logged
I can make window sizable and window will remember last size too. It will be OK for all
Posted by: Neil | Date: 2014-08-30 13:32 | IP: IP Logged
Hey that would be great - thanks very much.
Any comment on my other request ?
Thanks again,
Neil
Posted by: pspad | Date: 2014-08-30 16:10 | IP: IP Logged
Do you mean don't wrap long lines during printing? I added it into ToDo, but it hasn't big priority
Posted by: Neil | Date: 2014-09-01 21:35 | IP: IP Logged
Hi Jan,
Sorry for the confusion - I meant the other request in my post.
Neil:Can I also repeat my older request that the "Replace with" toggle stays on once the user has selected it.
Thanks
Neil
Posted by: pspad | Date: 2014-09-02 07:16 | IP: IP Logged
Neil:Hi Jan,Sorry for the confusion - I meant the other request in my post.
Neil:Can I also repeat my older request that the "Replace with" toggle stays on once the user has selected it.Thanks
Go to program settings / Tools
uncheck Replace - fill in Replace field with clipboard
Related width of the Search/replace dialog - it is done already, wait for next build
Posted by: Neil | Date: 2014-09-04 02:38 | IP: IP Logged
Hi Jan
pspad:Go to program settings / Tools
Sorry about confusion.
I would like this toggle value to be kept on:
pspad:Related width of the Search/replace dialog - it is done already, wait for next build
Please see reply to latest build.
Thanks,
Neil
Posted by: pspad | Date: 2014-09-04 06:15 | IP: IP Logged
Checkbox in Find in files is disabled due to users security. It's very easy to replace anything in big folder, but hard to return it back.
I don't think it's hard to handle it:
fill in search string
press TAB + Space
fill in replace string
