You are here: PSPad forum > English discussion forum > Customise "right click" menu within PSPad
Posted by: STing | Date: 2014-08-17 10:59 | IP: IP Logged
Hi Folks,
I need some guide to add a couple of custom items / shortcuts into the "right click" menu of PSPad.
For example, I just installed Emmet and I would like to add the "Match Tag Pair" and "Remove Tag" actions from the Script into this menu.
Is this possible?
Thx
Edited 1 time(s). Last edit at 2014-08-17 10:59 by STing.
Posted by: pspad | Date: 2014-08-17 12:23 | IP: IP Logged
No, it isn't possible.
I don't know Emmet and I don't know what Emmet does and how it can be used with PSpad
Posted by: STing | Date: 2014-08-17 13:03 | IP: IP Logged
Here's the link to Emmet:
docs.emmet.io
So there is no way to edit the "right click" (context) menu at all?
That's disappointing.
Edited 1 time(s). Last edit at 2014-08-17 13:05 by STing.
Posted by: carbonize | Date: 2014-08-18 10:10 | IP: IP Logged
Jan Emmet is what used to be called Zen Coding although you may not even know it as that. You type something like div*5 and press the relevant hotkey and it will create
<div></div>
<div></div>
<div></div>
<div></div>
<div></div>
It is a bit more powerful than that but I rarely need to create enough HTML to use it.
Carbonize
Posted by: Andreas | Date: 2014-08-18 10:52 | IP: IP Logged
Emmet offers a plugin for PsPad.
Posted by: Manfred62 | Date: 2014-08-18 14:52 | IP: IP Logged
PSPad 4.5.9 (2525)
