You are here: PSPad forum > English discussion forum > general questions on PsPad
#1 general questions on PsPad
Posted by: doctorlai | Date: 2014-08-14 22:04 | IP: IP Logged
1. does it use FastMM4 (the latest is 4.991)
2. is there going to be a 64-bit version of pspad?
3. how about pspad on linux, any plans?
#2 Re: general questions on PsPad
Posted by: pspad | Date: 2014-08-15 07:26 | IP: IP Logged
I don't use FastMM. It causes problems. I use FmpSysMM, it's more lightweight memory manager.
I have to upgrade code to new Delphi version to be able to compile it under 64b. But on the other side, I don't see the reason why PSPad should be 64 bit application.
I don't plan to make Linux version. Now is easy to run PSPad with Wine
#3 Re: general questions on PsPad
Posted by: francheu | Date: 2014-08-15 09:32 | IP: IP Logged
doctorlai:
PSPad works well with Wine.
If you want to enable scripts you need to install winetricks then install WSH support:
- "Select default Wine prefix"
- "Install a Windows DLL or component"
- Select "wsh57"
François
