You are here: PSPad forum > English discussion forum > can PSPad multiply (or divide) the indent number for all lines at once ?
Posted by: secarica | Date: 2014-05-01 16:26 | IP: IP Logged
I mean if there is a way to do this on the whole text:
aaaa
bbbb
cccc
to become
aaaa
bbbb
cccc
(or the reverse)
Edited 1 time(s). Last edit at 2014-05-01 16:27 by secarica.
Posted by: pspad | Date: 2014-05-01 20:29 | IP: IP Logged
Just now PSPad doesn't have such possibility
You can extend PSpad fuunctionality with own script in any language supported by Windows Scripting Host. Read the help or readme file in the .\Script subfolder
Posted by: Stefan | Date: 2014-05-02 17:28 | IP: IP Logged
You can simply search for the block of spaces or the tabs
and replace that by the double amount?
For example:
Text Text Text
....Text Text
....Text
........Text
Search 4 spaces and replace by 8 spaces:
Text Text Text
........Text Text
........Text
................Text
Posted by: secarica | Date: 2014-05-03 07:34 | IP: IP Logged
Myes, I can give a try, only that this way everything containing n spaces will be affected, not only the start of lines (that is some inline comments, position of comments at the end of line code, maybe other things too).
But thanks for the idea, that could be a starting point (right now I need to expand a code from 2/4/6/etc. leading spaces per line to 4/8/12/etc. spaces).
Cristi
Posted by: vbr | Date: 2014-05-03 14:48 | IP: IP Logged
secarica:Myes, I can give a try, only that this way everything containing n spaces will be affected, not only the start of lines (that is some inline comments, position of comments at the end of line code, maybe other things too).But thanks for the idea, that could be a starting point (right now I need to expand a code from 2/4/6/etc. leading spaces per line to 4/8/12/etc. spaces).
Cristi
for expanding the indentation spaces, you can use regular expression replacement; I believe, something like this might work:
>> Search for >>>
>>> replace with >>>
$1$1$2
[x] Regular expressions
i.e. all spaces from the beginning of the line up to the first non-space character are replaced with the doubled amount of spaces and the original following character.
Make sure to test it acording to your needs and code befor applying to to you codebase.
The opposite conversion to reduce the indentation cannot be done using a single regex in PSPad (as far as I know).
You could use the same method to anchor for the beginning of the line and the first non-space character, but you must enter the needed amounts of spaces manually step by step.
hth,
Posted by: myf | Date: 2014-05-03 22:11 | IP: IP Logged
If you need to change indentation of some code you may use this simple utility I made a long time ago for this purpose.
Posted by: secarica | Date: 2014-05-14 11:16 | IP: IP Logged
myf:If you need to change indentation of some code you may use this simple utility I made a long time ago for this purpose.
Worked very nice, thank you !
