You are here: PSPad forum > English discussion forum > Insert Text into lines
Posted by: Anonymous User | Date: 2013-08-08 07:34 | IP: IP Logged
Hi. I know I can Insert Text into lines... (Alt+I), but how do I delete text from lines? And if this is not possible, can it be implemented in PSPad, in a similar manner?
Edited 1 time(s). Last edit at 2013-08-08 07:34 by Skulstad.
Posted by: vbr | Date: 2013-08-08 08:50 | IP: IP Logged
Skulstad:Hi. I know I can Insert Text into lines... (Alt+I), but how do I delete text from lines? And if this is not possible, can it be implemented in PSPad, in a similar manner?
if you just need to delete a kind of text rectangle (a segment of characters from multiple lines), you can just use block selection and delete it.
To activate block selection (in standard setting), you can press [Alt] and make a normal select with the mouse.
If there is a larger portion of text to be handled this way, you can change the selection mode in the menu:
Edit: Selection type: Column selection
or click repeatedly in the respective icon in the statusbar (3rd from the left).
move the cursor to the planned beginning of the block, press F8 [toggle selection], move to the end of the selection and press F8 again.
hth,
Posted by: Anonymous User | Date: 2013-08-08 10:12 | IP: IP Logged
Hi and thanks.
I have a number of files with 20000+ lines, thus none of your suggestions will work (satisfactory).
- The first one is too time-consuming
- Number two doesn't work for me: I set the selection type to column selection, press F8, then F8 again, and selection type goes automatically back to normal, and EVERYTHING between the two F8s is selected.
Posted by: vbr | Date: 2013-08-08 11:40 | IP: IP Logged
Skulstad:Hi and thanks.I have a number of files with 20000+ lines, thus none of your suggestions will work (satisfactory).
you can change the selection type afterwards again, the selection limits should remain until you move the cursor; maybe it's more useful in different order then - set start-stop of the selection with F8 and set column mode.
hth,
Posted by: pspad | Date: 2013-08-08 12:39 | IP: IP Logged
You can use regular expressions in search/replace
e.g. you want to remove first 6 chars from each line:
search: ^.{6,6}(.*)
replace: $1
[x]Regular expressions
Posted by: Anonymous User | Date: 2013-08-09 05:34 | IP: IP Logged
Hi. I think your suggestion works. Being a novice in regular expressions, how do I remove characters 12 to 20?
Posted by: pspad | Date: 2013-08-09 08:10 | IP: IP Logged
search: ^(.{11,11}).{9,9}(.*)
replace: $1$2
Expression in round bracket are indexed and can be used in replace with $n
^begin of the line
. means any char
{min,max} - number of previous epressions occurence
* means any count of previous epression
So i search first 11 chars, then 9 and rest of the line
replace with first and third part (exclude the middle part)
Posted by: Anonymous User | Date: 2013-08-09 08:58 | IP: IP Logged
Thank you! Works perfectly!
Posted by: Stefan | Date: 2013-08-11 13:58 | IP: IP Logged
pspad:search: ^(.{11,11}).{9,9}(.*)
replace: $1$2
[x]Regular expressionsExpression in round bracket are indexed and can be used in replace with $n
^begin of the line
. means any char
* means any count of previous epressionSo i search first 11 chars, then 9 and rest of the line
{digit} - exactly amount of previous epressions occurence
search: ^(.{11}).{9}(.*)
replace: $1$2
There is also:
{min,} - min number of previous epressions occurence, up to as many as there is.
{,max} - zero or more, up to max number of previous epressions occurence.
The already mentioned:
{min,max} - at least min, up to max number of previous epressions occurence
Edited 1 time(s). Last edit at 2013-08-11 14:01 by Stefan.
