You are here: PSPad forum > English discussion forum > auto end tags
Posted by: yeeezooo | Date: 2013-02-22 07:19 | IP: IP Logged
Hi
I start using PSPad since yesterday
I downloading extension "Any_tag_close (Serge Balance)" and unpacking it to Script\JScript.
But I don't know how use it? For eg. I type < it automatically does the >, and I type b beetwen <> --> <b> and I press CTRL+. but I do not get end tag </b>, why?
Sorry for my english ;)
Posted by: pspad | Date: 2013-02-22 09:19 | IP: IP Logged
Do you see the menu item Script?
Ensure, PSPad scripting is enable in the program settings / System integration
Posted by: myf | Date: 2013-02-22 09:19 | IP: IP Logged
it places closing tag in place of cursor, so you have to move it after, to the place where you want it, e.g. write some content of the <b> tag and then press ctr+..
You should see Scripts in main menu and there (after upnpacking script, recompiling or restarting pspad) "web > autoclosing TAG..".
Posted by: carbonize | Date: 2013-02-22 10:37 | IP: IP Logged
Might be better off looking at Zen Coding (not emmet as that has a bug in PSPad). Then you would type the B and hit CTRL + ,
Plus Zen Coding supports a lot of other HTML expansions as can be seen on te cheat sheet at code.google.com
Carbonize
