You are here: PSPad forum > English discussion forum > PyPy Python under PSPad?
Posted by: nulife | Date: 2013-02-11 21:57 | IP: IP Logged
Dear Petr,
I've installed PyPy Python under Windows 7 (C:\Users\asus\pypy-2.0-beta1) and see the command prompt when starting pypy.exe.
But I couldn't see how to save and execute a new py script. I've added pypy.exe to the ocmpiler path, but I assume that's wrong. Please advise, many thanks!
Philip
Posted by: vbr | Date: 2013-02-11 22:28 | IP: IP Logged
nulife:Dear Petr,I've installed PyPy Python under Windows 7 (C:\Users\asus\pypy-2.0-beta1) and see the command prompt when starting pypy.exe.
Philip
I have no experiences with pypy, but in case you haven't tried it sofar, you may check the setting used for CPython.
I am using the following "compiler" settings for python 2.7 in PSPad:
Settings: Highlighters settings:: Python - Compiler:
Compiler:
C:\Python27\python.exe
Parameters:
"%File%"
[x] Capture Program output window
LOG Parser:
*File* "%F",*line %L*
To execute the currently active sourcefile from PSPad, just use:
File: Compile (Ctrl + F9)
If this dosn't work, you might check the PyPy documentation for the command line parameters it requires.
hth,
