You are here: PSPad forum > English discussion forum > Create project subdirectory from filesystem directory?
#1 Create project subdirectory from filesystem directory?
Posted by: RickH | Date: 2012-11-08 13:20 | IP: IP Logged
Is it possible to add entire directories into a project subdirectory automatically? This would be like the "Create Project from Directory" functionality but would be used on an existing project.
I imagine that this might involve an "Add Directories..." item in the context menu, but I don't know whether this kind of thing is even possible under Windows.
Thanks for the great editor. I've been using it for over 5 years now for everything.
#2 Re: Create project subdirectory from filesystem directory?
Posted by: pspad | Date: 2012-11-09 06:03 | IP: IP Logged
It means, each project folder must keep link to real path to allows you synchronize project.
This functionality isn't contained now.
