You are here: PSPad forum > English discussion forum > is the downloaded zip version of PSPAD really portable?
#1 is the downloaded zip version of PSPAD really portable?
Posted by: clair | Date: 2012-07-23 08:31 | IP: IP Logged
hi
I downloaded the .zip file in the download page.
after extracting it and executing PSPAD - it seems to be portable. is it?
when I say "portable" I mean that it doesn't leave any traces in the registry when it's not working/executed - e.g: when the program is closed.
well, does it leave traces ? is it portable ?
thanks!
xoxo
#2 Re: is the downloaded zip version of PSPAD really portable?
Posted by: pspad | Date: 2012-07-23 12:32 | IP: IP Logged
The only trace is one record in registry in HKCU\Software\PSpad
All configuration is in INI files inside PSPad folder. You can copy folder and run anywhere.
