You are here: PSPad forum > České diskuzní fórum > pád - crash
Posted by: Oskar | Date: 2026-09-10 13:17 | IP: IP Logged
Při uzavření PSPad spadne s chybovou hláškou.
Postup:
1. otevřít PSpad
2. do editoru vložit text níže
3. nic dalšího nedělat, jen zavřít.
Chyba:
Access violation at address 00007FF702F13E4F in module 'PSPad.exe' (offset 13E4F). Read of address 00000000039703BC.
PSPad verze 5.5.2 (851)
Text pro vložení:
<div data-dyn-serverid="48_0" data-dyn-rootserverid="3_0" data-dyn-controlname="AC_SalesQuotationListPage_MyActiveTile" data-dyn-role="CountTile" class="Auto tile" tabindex="0" data-dyn-role-orig="Tile" role="button" data-dyn-bind="visible: $data.Visible,
enabled: $data.Enabled,
click: $data.Clicked,
keyDown: $data.keyDown,
focusIn: $data.focusIn,
focusOut: $data.focusOut,
sizing: $dyn.layout.sizing($data),
css: {
'hasCountAndImage': $data.hasCountAndImage,
'tile-isZeroCount': $dyn.value($data.Count) == 0
skip: $dyn.ui.skip($data),
superTooltip: $dyn.ui.superTooltip($data),
attr: {
'data-dyn-button-display': $data.buttonDisplay,
'tile-type': $data.TileType,
'data-dyn-tile-size': $data.Size,
'aria-describedby': $dyn.ui.getDescribedByData($data)
}" data-dyn-template-applied="true" id="ac_userworkspace_1_AC_SalesQuotationListPage_MyActiveTile" data-dyn-lastvisible="true" dyn-data-supertooltip="true" data-dyn-button-display="Auto" tile-type="Count" data-dyn-tile-size="ShortWide" aria-describedby="ac_userworkspace_1_AC_SalesQuotationListPage_MyActiveTile_helptext"><span class="tileButton tile-count" data-dyn-bind="text: $data.Count">4</span><span class="tile-image imageBinder-emptyImage" data-dyn-bind="img: $dyn.ui.img($data)" aria-description="Chybí obrázek"></span><span class="tile-text" data-dyn-bind="id: $data.Id + '_text', text: $data._Label" id="ac_userworkspace_1_AC_SalesQuotationListPage_MyActiveTile_text">Moje aktivní nabídky</span><span class="tile-help" style="display: none; visibility: hidden;" data-dyn-bind="id: $data.Id + '_helptext', text: $dyn.value($data.HelpText) + ' ' + $dyn.label('CountTile_HelpText')" id="ac_userworkspace_1_AC_SalesQuotationListPage_MyActiveTile_helptext"> K obnovení dat o počtu dlaždic použijte klávesovou zkratku (Alt+Down)</span><div class="tile-refresh" aria-hidden="true" data-dyn-bind="flyout: $data.refreshFlyoutOptions">
<span class="tile-refreshIcon Info-symbol"></span>
<span class="tile-refreshHiddenLabel" data-dyn-bind="text: $dyn.format('{0} {1}', $dyn.label('Framework_Tile_MoreInfo'), $dyn.label('Framework_Tile_ButtonRole'))">Další informace Tlačítko</span>
</div><div role="alert" aria-live="assertive" aria-relevant="all" aria-atomic="true" class="tile-refreshFlyout sysPopup" data-dyn-lastvisible="false" style="display: none;">
<p data-dyn-bind="text: $data.timeSinceTileRefreshText"></p>
<p data-dyn-bind="text: $data.timeUntilTileRefreshText"></p>
<a data-dyn-role="AnchorButton" data-dyn-bind="
click: { callBack: $data.Clicked, optOutOfAllowSave: true },
css: { 'button-isDefault' : $data.DefaultButton },
attr: {
'name': $data.Name,
}" data-dyn-options="{Visible: $data.isManualRefreshEnabled, Label: $data.refreshNowLabel, Click: $data.refreshNow}" class="anchorButton" role="link" onclick="return false;" data-dyn-template-applied="true" data-dyn-controlname="13" id="ac_userworkspace_1_13" data-dyn-lastvisible="true" tabindex="0" dyn-data-supertooltip="true" name="13" data-dyn-button-display="Auto" style=""><div class="button-container">
<span class="button-image imageBinder-emptyImage" data-dyn-bind="img: $dyn.ui.img($data)" aria-description="Chybí obrázek"></span>
<span class="button-help" style="display: none; visibility: hidden;" data-dyn-bind="id: $data.Id + '_helptext', text: $dyn.value($data.HelpText)" id="ac_userworkspace_1_13_helptext"></span>
<span class="button-label" data-dyn-bind="
id: $data.Id + '_label',
ariaLabelFor: $dyn.ui.ariaLabelFor($data.Id, $data),
attr: { 'aria-describedby': $dyn.ui.getDescribedByData($data) }" id="ac_userworkspace_1_13_label" for="ac_userworkspace_1_13" aria-describedby="ac_userworkspace_1_13_helptext">Zahájit aktualizaci</span>
</div></a>
</div></div>
Posted by: pspad | Date: 2026-09-10 16:42 | IP: IP Logged
Stáhněte si aktuální 32bitovou verzi z oficiálních stránek.
Spusťte instalační program nebo rozbalte soubor ZIP do dočasného umístění v počítači.
Vyhledejte složku, do které jste nainstalovali 64bitovou verzi programu (výchozí \Program Files\PSpad)
Zavřete editor PSpad, pokud je spuštěn
Nainstalujte nebo zkopírujte a vložte obsah extrahovaného souboru ZIP do stejné složky.
Spusťte program a zkontrolujte, zda funguje podle očekávání.
Máte-li jakékoli dotazy nebo problémy, kontaktujte mě pro další pomoc.
Posted by: Oskar | Date: 2026-09-11 10:27 | IP: IP Logged
Aha, takže 64-bitová verze nefunguje, je to experimentální verze.
Edited 1 time(s). Last edit at 2026-09-11 10:29 by Oskar.
Posted by: pspad | Date: 2026-09-11 11:35 | IP: IP Logged
Oskar:Aha, takže 64-bitová verze nefunguje, je to experimentální verze.
Funguje, jen na nejakem hw ma problemy. Proto je oznacena jako experimentalni a pri problemech doporucuji 32b verzi.
64b postupne opravuji o nahlasene problemy.
