You are here: PSPad forum > České diskuzní fórum > Re: Pada na drzku
Re: Pada na drzku
#1 Pada na drzku
Posted by: DavidM | Date: 2026-03-31 12:58 | IP: IP Logged
Ahoj,
posledni dobou mi to dost pada na drzku, napr. pri otevreni souboru. Co s tim? Mam poslednoi verzi 5.5.1 a hazi mi to treba tohle:
PSPad.exe - application error
Access violation at address 0000000000995C57 in module 'PSPad.exe' (offset 1B5C57). Read of address 0000016A0000010F.
It's very important you write a comment to this exception (in English). In ideal case, send me sequence step by step to simulate exception. Try to find dependencies. Your effort will be useful for all PSPad users. Thank you.
Your exception comment:
Error log:
Exception address: 0000000000995C57
Stack list, generated 3/31/2026 2:45:02 PM
[0000000000995C57] Vcl.Graphics.TBrush.GetHandle + $27
[0000000000C22AE2] JclDebug.JclCreateStackList (line 5351, "JclDebug.pas" + 1) + $3F
[0000000000C229B2] JclDebug.DoExceptionStackTrace (line 5292, "JclDebug.pas" + 20) + $1F
[0000000000C2577B] JclDebug.DoExceptNotify (line 6741, "JclDebug.pas" + 7) + $0
[0000000000C11102] JclHookExcept.TNotifyItem.DoNotify (line 272, "JclHookExcept.pas" + 5) + $1D
[0000000000C1132C] JclHookExcept.DoExceptNotify (line 339, "JclHookExcept.pas" + 13) + $2B
Access violation at address 0000000000995C57 in module PSPad.exe (offset 1B5C57). Read of address 0000016A0000010F.
#2 Re: Pada na drzku
Posted by: AD7 | Date: 2026-04-07 13:57 | IP: IP Logged
ano v5.5.1 veľmi padala.
Terua je 5.5.2 - www.pspad.com
#3 Re: Pada na drzku
Posted by: erjuan73 | Date: 2026-08-24 07:58 | IP: IP Logged
děkuji za informaci
#4 Re: Pada na drzku
Posted by: ben.martin@seznam.cz | Date: 2026-09-08 14:56 | IP: IP Logged
Mám 64bit. verzi 5.5.2 (851) a padá mi taky. Často je to při opakovaném hledání (F3) pokud nenajde další výskyt. Ale v jiných různých situacích.
#5 Re: Pada na drzku
Posted by: pspad | Date: 2026-09-08 15:07 | IP: IP Logged
64b verze je oznacena jako experimentalni.
Nainstalujte si 32b nebo aspon posledni 64b build z developer fora. Tam uz je to opravene
