You are here: PSPad forum > České diskuzní fórum > batch files - nezvyrazneni pri otevreni kdyz obsahuje hexa
Posted by: lazna | Date: 2020-11-12 10:31 | IP: IP Logged
pspad 5.0.4 527 nezvyrazni syntaxi batch files, pokud tento na svem konci obsahuje nekolik tisic radek podobneho BIN kodu (viz nize). Pokud kliknu ve spodni liste na napis "Windows shell script" a z pulldown seznamu potvrdim predvybrany "Windows shell script", tak se to teprve obarvi.
V nastaveni mam AutoDetectBinary = 0
chapu ze mit tisice radku BIN kodu v batch sciptu asi neni uplne standardni, ale tusim ze v nejakych drivejsich vezrich to po nastaveni (AutoDetectBinary = 0) fungovalo, ale je mozne ze tehdy to byl HEXA kod.
L.
:+res:spd.exe:
o<iRU0~~r31onA4,nJ60XbVHe00000kMy=:0000000000000000000000000
0000000000000007Y:Qp4J&m(0ji6Sa?dLD+]{51x(+zoA=kPhvqNb,vqY$3
BrC47aAzQxazCZol~c-7zeS~~e`5l,bME/A00000n1jG41nT9u1nT9u1nT9u
w$f/w7wYaNw$f&x4eI5Dw$f=v:OD#VOM:VD2L]Jyqiz]23I>&Bqiz&0F+*D?
qiz(1cI`/+w$f]z68AXJ1nT6t/.MW<L-)4/ozP-hL-)1`y5e]LL-$3a0~s0t
L-)a?0~s0tqFxSO1nT9u000000000000000000000000000000p^>u:wqgf^
S*g500000000000[bKTj3JZ`H0dUsP0kFQn05bb/aGuBZ06?n00000:0rr91
01Ybg00ic21][S6000001][S6000000dVc>01Ybg000000~#.W000Mg00000
01Ybg00000000Mg0000001Ybg00000000005c8Xg0000000000CY>eetMK)9
0kGPPC^WRM0h7kgU?PiU0000000000`oA5n6Awak00000000000000000000
00000000007}7B+c&:kEnvxJs00961000000000000000000000000000000
00000000000000000000rzV^K0000005bb/01Ybg0000000Ao40000000000
00000Fb/PcrzV^L000000dUsP06?n00c`+H00Ao4000000000000000kMy/x
e](2Nv/MGe0kFQn0kGPP0j&gh0dk4L000000000000000kMy/10000000000
000000000000000000000000000000000000000000000000000000000000
0000000000000000000000000000000000Pe&+/&rzV^v4i#z<GF`cpfb5`M
R*]=/5O.NK0300VnHBHQjo><iaLzu#lmV?k/q]gQ1/6~E+L9n&GvsA)=^9OE
Z`4jbE*5n4qQs-jt?w]r127W:nWPJs8^wmt+?u{.G]ddo6K4dodXbHza}{{J
EIQWAB>.(HNRCV1/,D98A:5NZIj6YPc^[45~Z$,BHl#iEa6D:dXBWfdlj.ja
=T,DlWHtANe#464cqPTDg]rPkaAUgD=0&u$[Lj[>2qHOAtg)xN~BgdjgDs)(
Z}ev<jv1NVD<lGo`KUpM(L]q7JXtZQL)P<<<xf5Psqku?NGG4547vnf?:A{s
Pv-Z(K?^9qWOK}3dXj<YdRw)OIWUJabM/O+FRyLfNNlIpbAiJ?KT}>G:pcYk
Edited 1 time(s). Last edit at 2020-11-12 10:32 by lazna.
Posted by: pspad | Date: 2020-11-12 11:09 | IP: IP Logged
Dobrý den
PSpad má omezení na velikost pro automatické zvýraznění syntaxe kvůli rychlosti, které je asi v současné době zbytečné.
Jděte do nastavení programu, tlačítko přímá editace
Změňte řádek HLUpToSize=1000000
Tím nastavíte tento limit na 1MB, což by mělo být dostačující
Posted by: lazna | Date: 2020-11-12 11:46 | IP: IP Logged
Tato polozka tam aktualne neni a kdyz ji tam zapisu tak neprezije restart PSPadu (pri zapisu je pspad spusten pod adminem). Mate nejaky napad?
Posted by: pspad | Date: 2020-11-12 11:54 | IP: IP Logged
Ta položka tam standardně je, není třeba PSPad spouštět pod adminem
P.S. omlouvam se, napsal jsem původně špatně název HlUpToSize -> HLOnUpToSize
Edited 1 time(s). Last edit at 2020-11-12 11:55 by pspad.
Posted by: lazna | Date: 2020-11-12 13:06 | IP: IP Logged
Tak uz OK, diky!
BTW: Zkuste prosim nekdy zas mrknout na zvyraznovani tech windows shell scriptu, diky
Edited 1 time(s). Last edit at 2020-11-12 13:08 by lazna.
