You are here: PSPad forum > Russian discussion forum > ОШИБКА постоянно возникает при вводе "<br>"
#1 ОШИБКА постоянно возникает при вводе "<br>"
Написано: gorohovsky | Дата: 18.03.2016 00:23 | IP: IP записан
При попытке ввода <br> атоматически исправляет на <b> и зависает с ошибкой.
При чём такое было в Windows XP, повторилось в Windows 7 и сейчас повторяется в Windows 10. Как такое возможно???
Exception description:
Index is out ot range.
Exception class: EJclMapiError
Exception address: 004DC788
Stack list, generated 18.03.2016 3:21:00
[004DC783] JclMapi.TJclSimpleMapi.CheckListIndex (Line 487, "JCLMapi.pas" + 2) + $1D
[004DCF27] JclMapi.TJclSimpleMapi.SetSelectedClientIndex (Line 665, "JCLMapi.pas" + 1) + $D
[006EFE42] uJCLMail.SendMail (Line 39, "uJCLMail.pas" + 8) + $9
[006F015B] uJCLMail.SendReport (Line 97, "uJCLMail.pas" + 13) + $5C
[006D0660] uMain.TfPSPad.aBugReportExecute (Line 5848, "uMain.pas" + 0) + $0
[006DE188] uMain.TfPSPad.ActionListExecute (Line 10854, "uMain.pas" + 8) + $7
[004833EC] ActnList.TCustomActionList.ExecuteAction + $14
[00483034] ActnList.TContainedAction.Execute + $14
[00483CF3] ActnList.TCustomAction.Execute + $4F
[0042A03F] Classes.TBasicActionLink.Execute + $13
[00496ACF] Menus.TMenuItem.Click + $8F
[00497CBF] Menus.TMenu.DispatchCommand + $13
[0048B347] Forms.TCustomForm.WMCommand + $1F
[004A03F0] Controls.TControl.WndProc (Line 4645, "Controls.pas" + 53) + $6
[004A344F] Controls.TWinControl.WndProc (Line 6342, "Controls.pas" + 33) + $4
[004893AD] Forms.TCustomForm.WndProc + $421
[004F8121] TntControls.TWinControlTrap.WindowProc (Line 666, "TntControls.pas" + 19) + $5
[004A30CC] Controls.TWinControl.MainWndProc (Line 6237, "Controls.pas" + 3) + $6
[0042AE20] Classes.StdWndProc + $14
[004F7D7C] TntControls.TWinControlTrap.Win32Proc (Line 554, "TntControls.pas" + 12) + $19
[0048FADF] Forms.TApplication.ProcessMessage + $83
[0048FB16] Forms.TApplication.HandleMessage + $A
[0048FD36] Forms.TApplication.Run + $96
[006F2FAD] PSPad.PSPad (Line 69, "" + 43) + $7
Program : C:\Program Files (x86)\PSPad editor\PSPad.exe 4.5.6 (2427)
System : Workstation x64, Version: 6.2, Build: 23F0,
Processor: Intel, Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz, 3190 MHz MMX
Display : 1920x1080 pixels, 32 bpp
Active Controls Hierarchy:
TPSSynEdit "Editor1"
TfChildEdit "fChildEdit"
#2 Re: ОШИБКА постоянно возникает при вводе "<br>"
Написано: pspad | Дата: 05.12.2016 05:55 | IP: IP записан
Do you use the current PSPad 4.6.1 version? THis version should fix your problem.
As another solution switch off wordwrap mode
Exception list is from sending mail, cause you don't have any Simple mapi compatible client installed on your computer. You can copy/paste exception report and send it using any mail client to support address next time
