You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.0 (275) English
Goto Page: Previous1 2 3
#21 Re: PSPad unicode 5.0.0 (275) English
Posted by: gwinkless | Date: 05/02/2018 16:32 | IP: IP Logged
New version appears to have much wider indent in the project tree, which is annoying enough because they increase the width significantly.
It's more annoying because you can't actually click the triangles. This is v277:
In previous versions the width was nowhere near as bad (this is v271):
and the triangles were clickable.
Is this a config option I'm missing?
Ta
#22 Re: PSPad unicode 5.0.0 (275) English
Posted by: pspad | Date: 05/02/2018 20:06 | IP: IP Logged
Thank you for info. Problem found and fixed
#23 Re: PSPad unicode 5.0.0 (275) English
Posted by: tmtisfree | Date: 05/06/2018 11:59 | IP: IP Logged
@Jan
Could you make PSPad to remember the chosen ASCII table?
Each time PSPad starts, the ANSI Arabic is selected by default. Thanks
#24 Re: PSPad unicode 5.0.0 (275) English
Posted by: pspad | Date: 05/06/2018 12:53 | IP: IP Logged
You can change order of the code page list. Put your favourite on top. I will add functionality to remember last osed one
