You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.0 (275) English
Posted by: gwinkless | Date: 2018-05-02 16:32 | IP: IP Logged
New version appears to have much wider indent in the project tree, which is annoying enough because they increase the width significantly.
It's more annoying because you can't actually click the triangles. This is v277:
In previous versions the width was nowhere near as bad (this is v271):
and the triangles were clickable.
Is this a config option I'm missing?
Ta
Posted by: pspad | Date: 2018-05-02 20:06 | IP: IP Logged
Thank you for info. Problem found and fixed
Posted by: tmtisfree | Date: 2018-05-06 11:59 | IP: IP Logged
@Jan
Could you make PSPad to remember the chosen ASCII table?
Each time PSPad starts, the ANSI Arabic is selected by default. Thanks
Posted by: pspad | Date: 2018-05-06 12:53 | IP: IP Logged
You can change order of the code page list. Put your favourite on top. I will add functionality to remember last osed one
Posted by: Gabriel_ACE | Date: 2018-05-30 19:02 | IP: IP Logged
I don't find links for PSPad unicode 5.0.0 (277) English
where is it ???
Posted by: hhoefling | Date: 2018-05-30 20:40 | IP: IP Logged
there is no 277, 275 is latest ( i think)
by HH
Posted by: pspad | Date: 2018-05-31 04:41 | IP: IP Logged
Gabriel_ACE:I don't find links for PSPad unicode 5.0.0 (277) Englishwhere is it ???
277 is current full build
Posted by: DonVan | Date: 2018-06-04 19:50 | IP: IP Logged
PSPad,
When will you make a small update utility that will automatically close the application and download the updated files from the server?
Posted by: pspad | Date: 2018-06-04 19:59 | IP: IP Logged
Is it necessary? If pspad is installed in program files, such utility must run eith elevated rights.
Posted by: DonVan | Date: 2018-06-04 20:08 | IP: IP Logged
pspad:Is it necessary? If pspad is installed in program files, such utility must run eith elevated rights.
I do not insist, but before the release of the fifth version, the publication of updates was, to put it mildly, uncomfortable.
