You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.0 (251) English
Goto Page: Previous1 2 3
#21 Re: PSPad unicode 5.0.0 (251) English
Posted by: bluezero | Date: 2018-01-04 08:34 | IP: IP Logged
The main problem what is preventing me to use the v5 is the character set (UTF8) detection. Works fine in v4, but not in v5. In v4 i have UTF8 as default, so the fallback if it does not detect the charset is UTF8 and that works for me. Cant achieve the same with v5.
#22 Re: PSPad unicode 5.0.0 (251) English
Posted by: pspad | Date: 2018-01-04 08:51 | IP: IP Logged
Can you send me any sample where UTF-8 isn't correctly detected?
#23 Re: PSPad unicode 5.0.0 (251) English
Posted by: pfl74 | Date: 2018-01-08 00:13 | IP: IP Logged
Will there be a 64-bit version with scripting support soon?
#24 Re: PSPad unicode 5.0.0 (251) English
Posted by: pspad | Date: 2018-01-08 05:19 | IP: IP Logged
I can't promise it. I am still stucked with work in my job.
If there is anybody experienced with WSH (activex, OLE) scripting, I would await help.
Edited 1 time(s). Last edit at 2018-01-08 05:44 by pspad.
#25 Re: PSPad unicode 5.0.0 (251) English
Posted by: Freeman | Date: 2018-01-19 11:43 | IP: IP Logged
If file doesn't contains BOL or any char with value above 127, the content of file is same with ANSI and UTF-8. In this case there is no possibility how to detect content of the file.
In this case, is it better to prefer UTF-8 over ANSI and force file as UTF-8 encoded, to safely save all possible (new) characters input by user? When user isn't agree, he/she can change encoding manually. What do you think about it?
#26 Re: PSPad unicode 5.0.0 (251) English
Posted by: khagaroth | Date: 2018-01-19 15:29 | IP: IP Logged
Freeman:
In this case, is it better to prefer UTF-8 over ANSI and force file as UTF-8...?
^^This. Or rather use the default encoding set in the settings dialog whenever possible.
