You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 5.0.0 (241) English
Posted by: pspad | Date: 08/09/2017 18:46 | IP: IP Logged
Download links (5.4 MB):
PSPad 64 bit version preview without scripting support
Changes to 5.0.0 (235)
News
Take Command TC/TCC batch files user highlighter from user qwerky
New scripting function tabColor(string) sets/returns file tab color. Parameter is in RGB format: "RRGGBB"
Status bar shows position in formát: row:column(char position). The difference is with real tabs
Hash generator was rewriten. It now supports MD5, SHA1, SHA2
TextDiff and compare with file on disk - encoding is taken from the open file
Escape closes Code explorer in some cases when Escape exist option was off
Sort function adds empty line
Copy line (menu Edit / Lines manipulation) with spaces on the begin followed by UNDO and REDO added spaces on the end
Contex code explorer causes program hang-up with some files
HTML Multihighlighter - script tag wasn't recognized
Program settings / Registered file types and User highlighter dialogs don't allow "+" char in file extension
Wrong CP detection for empty unicode files with BOM only
Paragraph reformat caused program freeze if the right edge was set to zero
Posted by: Gabriel_ACE | Date: 08/11/2017 15:28 | IP: IP Logged
Excelent Work!
